u4gm Where Arbusto Farmacia Is in ARC Raiders Buried City Guide
Avatar du membre
BlueVibe
Message par BlueVibe »
Buried City's kind of spoiled me, and I'm not mad about it. Every run feels like it has a dozen ways to go right or wrong, and Arbusto Farmacia is the spot I keep drifting back to when I need to reset my kit and keep moving. If you're behind on meds or trying to stay on pace with Lance's tasks, it's hard to ignore. Some folks dodge the grind altogether and just Buy Arc Raiders Items, but even if you're looting the old-fashioned way, this pharmacy is one of the most reliable places to build a stash without gambling on a huge POI.
Getting There Without Getting Picked Off
You'll find Arbusto on the east side near Piazza Arbusto, sitting southwest of Town Hall. The problem isn't locating it. The problem is crossing the streets around it without becoming a free kill. If you spawn near Blue Gate, don't jog straight down the open road like you own the place. People watch that line because it's easy shots and easy loot. I cut through the busted parking garage ruins instead. You get cover, you get sound, and you can pause for a second to hear if someone's already posted up. When you peek out into the square, look for the washed-out green "Farmacia" sign against the concrete and dust.
Inside The Pharmacy: Fast Loot, Then Smart Movement
Downstairs is usually quick value. Bandages, basic stims, little stuff you can grab and go. The trap is lingering at the counter too long while you sort your bag. If you hear metal footsteps outside, assume it's not friendly and shift position. I like to sweep left to right, clear shelves, then check the back storage room before I even think about going upstairs. Corners are tight, lines of sight change fast, and somebody walking in behind you can lock you in with almost no warning.
Life Of A Pharmacist Route That Keeps You Alive
If you're on "Life of a Pharmacist," upstairs is where it gets sketchy. It's quieter up there, which sounds nice until you realise quiet means you'll hear them too late if you're stuck in a dead end. I take the photos in a simple order: first the family portrait in the living room, then the kitchen area, then the workbench. Last is the bedroom desk, because it's a commit. Once you're in that room, you've basically told anyone nearby exactly where you are. Keep your exits in mind and don't be afraid to bail and reset if the stairwell sounds wrong.
The Hidden Cache And The Economy Reality Check
Down in the back storage room, there's a loose panel that can hide a small cache. It's not guaranteed, but I've noticed it shows up more when I actually clear the main counter loot first, like the game's nudging you to fully sweep the place. When it hits, it can save a run—crafting mats, higher-tier parts, the kind of stuff you don't want to lose on a bad rotation. And yeah, the economy can feel brutal when you're getting rolled by campers or bad spawns, so I get why some players lean on marketplaces for a quicker reset; if you do, pick something reputable with straightforward delivery and support like u4gm so you're not wasting time when you just want to queue up again.
