How to find out the day of a particular date
evasingle
Message par evasingle »
Hello, Guest!
Article about how to find out the day of a particular date:
Try it out! Specific Day Finder. With this browser-based application, you can find calendar dates by the given month, day of the month (day number), and day of the week.
>>> GO TO SITE <<<
In the options, you can specify the date range to use for searching the dates and customize the search criteria. You can choose the month name (Jan, Feb, Mar, …), and/or the day number (1, 2, 3, …), and/or the day name (Mon, Tue, Wed, …) for the search. You can also select a predefined output date format, create a custom output date format, adjust the padding of date components, and set the search result separator character. Created by computer nerds from team Browserling. Specific Day Finder. World's Simplest Time Tool. With this browser-based application, you can find calendar dates by the given month, day of the month (day number), and day of the week. In the options, you can specify the date range to use for searching the dates and customize the search criteria. You can choose the month name (Jan, Feb, Mar, …), and/or the day number (1, 2, 3, …), and/or the day name (Mon, Tue, Wed, …) for the search. You can also select a predefined output date format, create a custom output date format, adjust the padding of date components, and set the search result separator character. Created by computer nerds from team Browserling. You're using the free plan. The free plan lets you use time tools for personal use only . Upgrade to the premium plan to use time tools for commercial purposes. Additionally, these features will be unlocked when you upgrade: You're using the free plan. The free plan lets you use time tools for personal use only . Upgrade to the premium plan to use time tools for commercial purposes. Additionally, these features will be unlocked when you upgrade: Text has been copied to clipboard. Yay! The text has been copied to your clipboard. If you like our tools, you can upgrade to a premium subscription to get rid of this dialog as well as enable the following features: Date Search Range. Specific Day, Month, Weekday. Output Date Format. What Is a Specific Day Finder? This is a quick online utility for generating a specific calendar date that matches your criteria. For example, you can find all Fridays the 13th that fall in the same year, or you can find when the New Year falls on a Saturday, or you can print all Mondays in September. Our program can find the matching dates within one year (such as year 2025) or any custom date interval (such as all years from 2025 to 2035). You can enter the start and end dates for the search in the YYYY-MM-DD" format in the options. For example, if the start date is 2000-01-01 and the end date is 2050-01-01, then the program will generate all specific dates from the first half of the 21st century. The search can be narrowed down by specifying the day, month, and day of the week. The day can be entered in the options as a number from 1 to 31. If this field is left empty, then any day will be used. The month and day of the week can be selected from a list. For example, you can choose that the month is only "February" and that day of the week is only "Wednesday". You can also set them to "Any Month" and "Any Day of Week". When specifying the date components you are interested in, you can choose just one of them, or choose two, or specify all three, which will find the most specific date possible. For example, you can specify that the day must equal to "12" and allow any month and day of the week. In this case, the program will generate every 12th day of each month as the output. If you specify the month as "June" and skip the day and weekday, then the tool will generate the June calendar with all days of June. If you set the day of the week to "Thursday", then our algorithm will find all Thursdays in all months. If you set the day to "12" and the month to "June", then you'll get all June 12th dates (one from each year in the search range). If you specify the day to be "12" and the day of the week to be "Thursday", then the search results will contain all Thursdays that fall on the 12th calendar day of the month (such as "May 12, 2022"). If you select the month "June" and the day of the week "Thursday", you will get the dates of all Thursdays in June. And if you specify all three components: the day "12", the month "June", and the weekday "Thursday", then you'll get only Thursdays that fall on the 12th of June of any year, such as "Thu, Jun 12, 2025", "Thu, Jun 12, 2031", and "Thu, Jun 12, 2036 ". The search result output can be tailored to your needs – you can display the calendar dates in numeric or textual formats and create custom date templates by switching to the custom mode in the predefined format list. When creating a custom date template, use the date format specifiers "YYYY", "MMM", "MM", "DD", and others. You can also control the zero-padding in dates (make years be four digits long and make months and days be two digits long), and customize the delimiter symbol that is printed between the generated dates. Timeabulous! What Is a Specific Day Finder? This is a quick online utility for generating a specific calendar date that matches your criteria. For example, you can find all Fridays the 13th that fall in the same year, or you can find when the New Year falls on a Saturday, or you can print all Mondays in September. Our program can find the matching dates within one year (such as year 2025) or any custom date interval (such as all years from 2025 to 2035). You can enter the start and end dates for the search in the "YYYY-MM-DD" format in the options. For example, if the start date is 2000-01-01 and the end date is 2050-01-01, then the program will generate all specific dates from the first half of the 21st century. The search can be narrowed down by specifying the day, month, and day of the week. The day can be entered in the options as a number from 1 to 31. If this field is left empty, then any day will be used. The month and day of the week can be selected from a list.
