MMOexp POE 2: A Guide to Maximizing Your Resources
Calista
Message par Calista »
Mastering Spirit in Path of Exile 2: A Guide to Maximizing Your Resources
In the treacherous world of Path of Exile 2, resource management is more crucial than ever for POE2 Currency building a powerful character and surviving the chaos of Wraeclast. While Life and Mana have been the cornerstone resources for years, Path of Exile 2 introduces a new mechanic called Spirit, which adds a layer of strategic depth to how you build and play your character. Understanding Spirit and how to increase your maximum Spirit is key to unlocking the potential of many powerful builds, especially those centered around minions or permanent buffs.
Understanding Spirit and How It Works
Spirit works in an entirely different way than Life and Mana. Life is depleted when you take damage, and Mana drains as you use abilities. Spirit, on the other hand, is primarily reserved for long-term abilities, such as minion summons or self-buffs, which means that it works based on a reservation system. This system allows specific skills or buffs to permanently reserve a portion of your Spirit pool, reducing the amount available for other abilities.
For instance, if you’re running a build that involves summoning permanent minions, each summon will reserve a chunk of your Spirit. The same goes for certain powerful buffs that remain active until deactivated, such as the Mercenary’s ability to deal explosive damage to nearby enemies when Overpowered. This ability, for example, requires 30 Spirit to activate, which stays locked in your Spirit pool until you deactivate it.
Unlike Mana, which can regenerate over time, Spirit does not regenerate passively. This makes it imperative for players to focus on increasing their maximum Spirit capacity to ensure they can continue utilizing Spirit-heavy abilities without running into Path of Exile 2 Currency for sale resource shortages.
