If you’ve spent enough time roaming the Appalachian wasteland with friends, you know that in Fallout 76, being the team’s “pack mule” can be a real game-changer. Whether you’re hauling extra ammunition, carrying loot for crafting, or just holding everyone’s legendary drops until the end of the run, certain items can make this role much more efficient. Over time, I’ve tested a lot of gear and perks to see what really helps in team play. Here are my top 11 picks for improving your load-carrying game.
1. Pocketed Armor Mods
Upgrading your armor pieces with the Pocketed mod is one of the easiest ways to boost carry weight. Each piece adds a noticeable amount, and when stacked across your gear, it really adds up.
2. Excavator Power Armor
This iconic set isn’t just for mining — it offers a hefty +100 carry weight bonus when worn as a full suit. Perfect for long expedition days with your squad.
3. Backpack (Standard or High-Capacity)
Unlocking and upgrading a backpack is a must. The High-Capacity mod especially is a huge help for anyone taking on a support role in the team.
4. Bear Arms Perk Card
If you’re packing a lot of heavy weapons for your group, Bear Arms is essential. It reduces weapon weight significantly, leaving more room for other supplies.
5. Travelling Pharmacy Perk Card
For the medic-minded player who carries stacks of Stimpaks and RadAway, Travelling Pharmacy cuts their weight dramatically. Your back will thank you.
6. Strong Back Perk Card
Sometimes the simplest perk is the most effective. Strong Back increases carry weight directly, and it’s a solid pick for any pack mule build.
7. Food Buffs: Grilled Radstag
Cooking up Grilled Radstag before a trip is a classic move. It provides a temporary carry weight boost and is easy to prepare if you keep Radstag meat in storage.
8. Chem Buffs: Overdrive and Psychobuff
Some chems like Psychobuff offer not just combat bonuses, but also an increase to Strength, which indirectly boosts your carry weight.
9. Power Armor Calibrated Shocks
If you’re already wearing power armor, swapping in Calibrated Shocks for the leg pieces adds extra carry weight on top of your existing bonuses.
10. Perk Synergy: Pack Rat + Traveling Pharmacy + Bear Arms
Mixing perks that reduce item weights across multiple categories can make a massive difference. This synergy frees up space so you can carry more for your team.
11. Stockpiling Caps and Supplies
While not a direct gear upgrade, having resources ready to buy Fallout 76 Items or Buy Fallout 76 Caps from in-game vendors or other players means you can adapt your loadout on the fly. If your squad needs extra ammo or crafting mats mid-session, you’ll be ready.
Final Thoughts
Playing as the team’s pack mule in Fallout 76 is more than just about having big pockets — it’s about smart planning. Combining the right armor mods, perks, and consumables turns you into a walking supply depot that keeps your squad running at full strength. Whether you’re running daily ops, farming events, or exploring uncharted corners of the map, these 11 items and strategies will help you carry your weight — and then some — for your team.
Do you want me to also prepare a more in-depth version with perk card rank recommendations and specific crafting locations so it reads like a full-blown Fallout 76 build guide? That could make it even more authoritative.
Fallout 76 Items That Improve Pack Mules for Team Play: Top 11
HistoryHunter
