The Templar is the main tank class in Aion 2. If you have played tank roles in MMOs before, the general idea will feel familiar. Your job is not to deal the most damage, but to control enemies, take hits for the group, and keep fights stable. In practice, most groups rely heavily on a good Templar to make content feel smooth and manageable.
This article explains how the Templar actually works in day-to-day gameplay, based on how most players use the class rather than theory or marketing.
What Is the Templar’s Core Role?
In Aion 2, the Templar is built to be a frontline defender. Most of its skills are designed around defense, threat generation, and damage reduction. Compared to other classes, damage output is lower, but survivability is much higher.
In general, players expect the Templar to:
Pull enemies and start fights
Keep enemy attention focused on themselves
Reduce incoming damage to the party
Control positioning and pace of combat
In group content, the Templar usually sets the rhythm. If pulls are clean and positioning is good, the rest of the group can focus on damage and healing without panic.
How Does Tanking Work in Practice?
Tanking as a Templar is more than just standing still and blocking hits. Most players quickly learn that active decision-making matters.
A typical fight often looks like this:
Pull enemies using a gap-closing or pull skill
Establish threat quickly with shield and strike skills
Position enemies so they face away from the group
Rotate defensive skills based on incoming damage
Adjust if new enemies join the fight
Templars rely on a mix of active skills and passive defenses. Many passive abilities trigger shields or damage reduction when certain conditions are met, which rewards consistent and controlled play rather than panic button usage.
How Important Is Positioning?
Positioning is one of the most important skills for a Templar. In general, most enemies should be faced away from your party to avoid cleave damage. This becomes especially important in dungeons and boss fights.
Most players develop habits like:
Pulling enemies into corners or against walls
Keeping bosses stationary for easier damage uptime
Moving only when necessary to avoid disrupting the group
Because the Templar is slower than lighter classes, unnecessary movement often causes more problems than it solves. Good positioning early usually means less movement later.
What Weapons and Gear Do Templars Use?
Templars are limited in weapon choice. Most players use a one-handed sword or mace with a shield. This setup maximizes block chance and defensive stats, which directly support the tank role.
A greatsword is sometimes used as a secondary option, usually in solo play or low-risk content. However, in group content, shield usage is almost always preferred.
Gear progression focuses more on defense, health, and mitigation rather than raw damage. In practice, upgrading defensive stats often has a bigger impact on group success than increasing personal DPS.
How Does the Templar Handle Mobility?
Traditionally, Templars were known for being slow. In Aion 2, this has improved significantly. Based on testing feedback, the class now feels more responsive and flexible.
Most players rely on:
Shield-based rush skills to close gaps
Pull abilities to bring enemies closer
Short movement bursts rather than constant chasing
The class is still melee-focused, and ranged options are limited. Distance-based skills usually have short range and long cooldowns, so staying in melee range is almost always the better choice.
What Are the Key Active Skills Used in Combat?
Templar combat revolves around active skills that require constant input. These skills form the backbone of threat generation and defense.
Commonly used skills include:
Ferocious Strike
Pummel
Shield Smite
Judgment
Shield Rush
Warding Strike
Defiance
Punishment
Annihilate
Most players don’t use these randomly. Skill chains matter, and timing defensive abilities correctly often makes the difference between a smooth pull and a wipe.
In general, experienced players focus on maintaining threat first, then layering defense as damage increases.
How Does the Templar Perform in Group Content?
In group play, the Templar is usually indispensable. Dungeons, elite areas, and boss encounters are designed with a dedicated tank in mind.
Most healers prefer running with a Templar because damage intake is more predictable. Damage dealers also benefit from stable enemy positioning and fewer interruptions.
While some groups may experiment with alternative setups, the Templar remains the most reliable option for consistent tanking in Aion 2.
What About Solo Play?
Solo play as a Templar is safe but slower. Most players can survive difficult encounters without much risk, but fights take longer due to lower damage output.
This makes the class appealing to players who value stability over speed. However, players focused on fast leveling or farming often choose other classes.
Some players discuss efficiency topics, including gearing paths or optional systems, and you may occasionally see mentions like Aion 2 cash shop alternative U4N in community discussions. In practice, solo progression as a Templar still depends mostly on patience, positioning, and steady gear upgrades rather than shortcuts.
How Has the Templar Changed Compared to the Original Aion?
Based on focus group testing, the Templar is considered one of the most improved classes in Aion 2. Combat feels smoother, skill chains flow better, and mobility is less restrictive.
The core identity remains the same. You are still a defensive tank first and foremost. What has changed is how active and engaging the role feels moment to moment.
