U4GM - How to Beat Bosses Without Rolling in Elden Ring
Posté : 06 mai 2025, 08:11
In Elden Ring Runes, mastering boss fights is often synonymous with mastering the roll. Rolling to dodge powerful attacks is a cornerstone of the game’s combat mechanics. However, not every player wants to rely on reflex-based evasive maneuvers. Whether due to personal playstyle, physical limitations, or a desire to challenge themselves, some players seek alternative strategies. If you're determined to beat bosses without rolling, this guide provides proven tactics and expert advice that prioritizes skill, preparation, and intelligent gameplay.
Embrace Alternative Defensive Tactics
1. Shield Blocking and Guard Counters
Instead of rolling, invest in a high-stability shield. Greatshields like the Erdtree Greatshield or Beast Crest Heater Shield can absorb significant damage, especially when upgraded. By holding your ground and blocking incoming attacks, you conserve stamina and reduce risk. Guard counters (light attack after a block) offer a powerful way to punish enemies immediately after defense.
2. Perfect Your Timing with Parrying
Parrying may be more demanding than rolling, but it’s a viable alternative if mastered. Many humanoid bosses, like Godrick the Grafted or Morgott, are susceptible to parries. Use parry-friendly shields like the Buckler or Red Thorn Roundshield to practice in lower-level areas before challenging major bosses.
3. Learn Boss Patterns Thoroughly
If you’re not rolling, you need to know every move your opponent makes. Patience becomes your strongest weapon. Study the wind-up, range, and recovery of each attack to know when to block, counter, or reposition. This approach transforms fights into methodical duels rather than chaotic scrambles.
Leverage Terrain and Summons
4. Use the Environment
Many boss arenas contain natural cover, elevation changes, or objects that break line-of-sight. These can give you breathing room or block projectiles. Use these to reposition instead of dodging.
5. Spirit Ashes and NPC Allies
Summoning isn’t cheating—it's part of Elden Ring's design. Powerful Spirit Ashes like Mimic Tear or Lhutel the Headless can draw aggro, allowing you to play more defensively. NPC summons, available outside many boss arenas, provide additional support that can give you openings to attack safely.
Optimize Gear and Builds
6. Heavy Armor and Poise
Rolling usually requires light or medium loads. Since we’re not rolling, go full heavy. Equip armor sets like Bull-Goat or Lionel's Set to maximize poise and damage resistance. This allows you to endure multiple hits without staggering, which is crucial when standing your ground.
7. Weapon Choice Matters
Choose weapons that reward timing and reach. Spears, halberds, and colossal weapons can be used safely behind a shield or from mid-range. Weapons with hyper armor on heavy attacks (like Greatswords) allow you to trade hits favorably.
8. Buffs and Consumables
Use Physick flasks, buffs like Flame, Grant Me Strength, or consumables that boost defense or stamina regeneration. These can tip the balance in your favor, especially during the punishing second phases of most boss fights.
Farming and Progression Help
9. Don’t Be Underleveled
Taking on bosses without rolling increases the difficulty, so level up smartly. Prioritize Vigor, Endurance, and your primary damage stat. If you need extra runes for leveling or upgrading gear, consider rune farming in high-yield areas like Mohgwyn Palace. Alternatively, you can purchase Elden Ring runes from trusted online vendors to speed up progression—just ensure it’s a reliable source with a solid reputation, like U4GM.
Beating Elden Ring bosses without rolling is entirely possible and deeply rewarding. It pushes you to adopt different playstyles, focus on strategy over reflex, and make the most of the game’s diverse combat systems. Whether you're a seasoned player looking for a fresh challenge or someone who prefers deliberate gameplay, these techniques will help you not only survive but thrive in the Lands Between. And if you're ever short on resources, remember that it’s perfectly viable to purchase Elden Ring runes to support your journey.
