U4GM - Blox Fruits: 14 Must-Know Tricks for Faster Leveling
Posté : 11 juil. 2025, 03:54
par EmberSonata
Leveling up in Blox Fruits can be a grind, but with the right strategies, you can speed up your progress and dominate the seas faster. Whether you're a beginner or a seasoned player, these 14 tricks will help you maximize your efficiency and reach higher levels in no time.
1. Focus on Efficient Farming
Target enemies that give the best EXP for your current level. Avoid wasting time on low-tier mobs unless you're completing specific quests.
2. Complete Boss Quests
Bosses drop significant EXP and sometimes rare Blox Fruits Items for sale. Always check the quest board and prioritize high-reward fights.
3. Use the Right Fruit
Some Devil Fruits, like Light or Magma, have excellent AoE attacks for farming. If you don’t have one, consider saving up to buy Blox Fruits Money and invest in a top-tier fruit.
4. Grind in Private Servers
Fewer players mean more mobs and bosses for you. This reduces competition and speeds up leveling significantly.
5. Take Advantage of 2x EXP Events
Always check for in-game events or codes that grant double EXP. Stack these with other boosts for insane leveling speed.
6. Equip the Right Accessories
Items like the Black Cape or Ghoul Mask provide stat boosts that help you farm faster. Keep an eye out for useful gear.
7. Team Up with Higher-Level Players
Joining a strong crew or party lets you take on tougher enemies while sharing EXP. Plus, experienced players can offer valuable tips.
8. Master Your Combos
Efficient combos reduce time spent per kill. Practice chaining moves to clear waves quickly.
9. Use Codes for Free Boosts
Blox Fruits frequently releases codes for free EXP boosts, Beli, or items. Sites like U4GM often compile active codes—check them regularly.
10. Optimize Your Stats
Early on, focus on melee and defense to survive longer. Later, balance stats based on your preferred fighting style.
11. Skip Weak Quests
Some quests offer minimal rewards. Prioritize those that give the most EXP relative to the effort required.
12. Farm in the Right Sea
Each sea has level-appropriate enemies. Don’t linger in lower seas once you’ve outgrown them.
13. Use Boats for Mobility
Faster travel means less downtime between farming spots. Upgrade or buy a good boat early.
14. Sell Unnecessary Items
If you’re short on funds, sell extra Blox Fruits Items for sale to afford better gear or fruits.
By following these tricks, you’ll level up faster and enjoy Blox Fruits with less frustration.
