Courage Dagger Stats, Tips, and Usage for Aion 2
Posté : 30 déc. 2025, 03:31
If you are playing an Assassin in Aion 2, you have probably heard about the Courage Dagger. It’s one of the unique weapons designed specifically for this class. In this guide, I’ll break down what this dagger does, how to get it, and how it fits into regular gameplay, based on what most players experience.
What Is the Courage Dagger?
The Courage Dagger is a dagger-type weapon exclusive to Assassin classes in Aion 2. Its main stats are:
Item Level: 55
Attack: 196 - 252
Accuracy: 50
Critical Hit: 200
Block: 50
PvE Damage Boost: Yes
Manastone Slots: 4
In general, players consider it a solid mid-to-high-level weapon for Assassins. It balances high attack power with a decent critical rate, which suits the fast, high-damage playstyle that most Assassins use.
Who Can Equip the Courage Dagger?
Only Assassin-class characters can equip the Courage Dagger. Most other classes cannot use it, so it’s not a versatile weapon outside this specific role.
Because it is unique, owning one is a mark of progression for many players, and it’s generally considered a reliable PvE weapon for Assassins at this level.
How Do the Stats Work in Practice?
Here’s a breakdown of what the key stats mean during normal gameplay:
Attack (196-252): This determines the damage your attacks do. Most players find the upper range of 252 sufficient for mid-level Abyss farming or questing.
Accuracy (50): Accuracy helps ensure your attacks hit. For Assassins, who often rely on consistent damage output, this is generally adequate for most PvE situations.
Critical Hit (200): Assassins usually focus on criticals to maximize damage. A critical value of 200 is considered solid for this stage of the game, allowing for frequent high-damage hits.
Block (50): Although Assassins are not tanks, this block value provides minor survivability, useful in group content or solo farming.
PvE Damage Boost: This bonus makes the dagger slightly stronger against monsters, which is helpful for most players running regular quest lines or Abyss encounters.
Manastone Slots (4): These slots allow you to add enhancements. Most players prioritize offensive manastones to increase attack or critical hit rates.
Where Can You Get the Courage Dagger?
Currently, the Courage Dagger drops in the Abyss. Based on general player experience:
It is not craftable at the moment.
The drop is usually tied to mid-to-high-level Abyss encounters.
Specific bosses or locations are not fully detailed yet, but most players track Abyss events or elite spawns to maximize their chances.
In general, farming the Abyss is the usual way players aim to get this dagger. Many Assassins join groups to target bosses that have better drop rates.
Can You Craft the Courage Dagger?
As of now, there are no crafting recipes for this dagger. Players cannot make it using standard crafting professions. If you are used to creating weapons yourself, you’ll need to rely on drops rather than crafting for this item.
Should You Buy or Sell the Courage Dagger?
The in-game gold value can reach up to 24,430, but this fluctuates depending on your server economy and how rare the item is in your current patch.
Buying: Most players only buy it if they are struggling to get the drop and the price is reasonable.
Selling: If you already have one and want to make gold, it can fetch a decent amount, but many Assassins prefer to keep it due to its stats and utility.
How Does the Courage Dagger Compare to Other Assassin Weapons?
In general terms:
Its attack and critical stats are competitive for mid-game content.
The four manastone slots are above average, giving room for enhancements.
PvE-focused players tend to find it more effective than general-purpose daggers, especially in group or Abyss farming.
Most players eventually look for upgrades as they move into endgame content, but at level 55, this dagger is usually a main weapon.
Tips for Using the Courage Dagger
Based on common player behavior:
Focus on Critical and Accuracy Manastones: Since Assassins rely on high burst damage, these stats complement the dagger’s natural strengths.
Pair With PvE Buffs: Using class skills or consumables that enhance damage in PvE will make the dagger more effective.
Abyss Farming: Target areas where Assassins have higher drop rates or form groups to increase the chance of obtaining it.
Upgrade Over Time: Keep an eye out for upgrades or higher-tier daggers. Most players replace it as they enter higher-level content, but it serves well until then.
The Courage Dagger is a solid, mid-level weapon for Assassins in Aion 2. Most players value it for its high attack, critical hit, and PvE damage boost. While it is currently only obtainable via Abyss drops, it provides a dependable weapon for leveling, farming, and mid-game PvE activities. Enhancing it with manastones and using it strategically in Abyss farming can make it a key tool in any Assassin’s arsenal.
U4N makes it simple to buy Aion 2 gold online: https://www.u4n.com/aion-2/kinah
Item Level: 55
Attack: 196 - 252
Accuracy: 50
Critical Hit: 200
Block: 50
Manastone Slots: 4
In general terms:
