How to find which day was on date
Posté : 04 févr. 2026, 16:02
Hello, Guest!
Article about how to find which day was on date:
Returns the day of the month, a number from 1 to 31. Syntax. Parameters.
Click here for How to find which day was on date
Term Definition date A date in datetime format, or a text representation of a date. Return value. An integer number indicating the day of the month. Remarks. The DAY function takes as an argument the date of the day you are trying to find. Dates can be provided to the function by using another date function, by using an expression that returns a date, or by typing a date in a datetime format. You can also type a date in one of the accepted string formats for dates. Values returned by the YEAR, MONTH and DAY functions will be Gregorian values regardless of the display format for the supplied date value. For example, if the display format of the supplied date is Hijri, the returned values for the YEAR, MONTH and DAY functions will be values associated with the equivalent Gregorian date. When the date argument is a text representation of the date, the day function uses the locale and date/time settings of the client computer to understand the text value in order to perform the conversion. If the current date/time settings represent dates in the format of Month/Day/Year, then the string, 1/8/2009", is interpreted as a datetime value equivalent to January 8th of 2009, and the function returns 8. However, if the current date/time settings represent dates in the format of Day/Month/Year, the same string would be interpreted as a datetime value equivalent to August 1st of 2009, and the function returns 1. Example: Getting the day from a date column. The following formula returns the day from the date in the column, [Birthdate]. Example - Getting the day from a string date. The following formulas return the day, 4, using dates that have been supplied as strings in an accepted text format. Example - Using a day value as a condition.
how to find date in calendar
how to find day by date
how to find day on any date
how find day of any date
