Diablo 4: Best Gear and Stats for Crushing Hand Spiritborn Build | Dominate with U4GM Support
Posté : 23 avr. 2025, 05:35
par jeanbb
Looking to hit max level fast in Diablo 4: Vessel of Hatred? The Crushing Hand Gorilla Spiritborn build is a speed-leveling machine. Combine that with top-tier items from diablo 4 boost, and you’ll carve through levels like a hot knife through butter.
The Build That Makes XP Farming Fun
The key to quick leveling is burst AoE damage and movement speed. Crushing Hand gives you both when paired with Gorilla Spirit enhancements.
Speed-Leveling Setup:
Crushing Hand + Spirit Pulse = Clear mob packs fast
Jungle Dash = Increases mobility between packs
Feral Surge = Regenerates Spirit when moving or dashing
XP Efficiency Tips
Focus on open-world events and Nightmare dungeons
Use elixirs and XP boosts with fast-clearing zones
Gear with Spirit Cost Reduction lets you keep spamming your combo
Quick Progression Starts with U4GM
Farming gear and gold manually? That’s slow. Use U4GM to gear up instantly with the best Diablo 4 gold so you can hit endgame in record time. Power leveling has never been so easy!
